Welcome to Club Chopper! The World's largest
and coolest place to be on the net if you dig the following!
- » Custom Bikes
- » Killer Paint
- » Old School Craftsmanship
- » Building and Wrenching
- » Hot Babes
- » Chopper Build Logs
YES! I want to register an account for free right now!
p.s.: For registered members this ad will NOT show
09-18-2016, 11:43 PM
QL
Downunder Chopper Build
Thought I would introduce myself, I'm building a Rigid 300 rear Chopper, so far specs are 113 S&s engine out of a drag bike seriously modified heads, had a an S&S super D carb on it, however will replace with a Mikuni, Genuine FXST springer front end running short rises and flat drag style bar, still making a decision on which Right side drive to run, running traditional spoked wheels, big 3inch belt Primary with Chain rear drive. looking forward to reading about all your builds and picking your brains
Advertising
09-19-2016, 07:39 PM
FL
Welcome to CC!
09-20-2016, 10:30 AM
Slow=Smooth, Smooth=Fast
VA
welcome, and good luck!
09-20-2016, 04:33 PM
Ql
i am in Australia as well in Brisbane ,I have a Kraftech 240 wide RSD frame,with S&S 111 in it originally had a Accesories Ulimited 6 Speed lasted about 15000 km,then started jumping out of third gear thought about fixing it then found Baker 6 speed RSD new in the states for 2.200 dollars had only been used for mock up never run. So jumped at it still cost 3.700 AUD delivered with GST and all.Compliancing is probably
. your biggest worry everything has to be ADR compliant.I got mine complianced in Brisbane for 2500 dollars which included brake test, noise test, and engineers report.. If there any advice needed let me know...............
09-25-2016, 06:39 AM
la
Sounds good, please post some pics..
2004 Ultima 127 Chopper
Shreveport Louisiana
Thread Tools |
Display Modes |
Linear Mode
